Model 41-280 "slide Rule" dial
Bill , here is a little more detail on the Rock Sea sticker .Mine is "Volume "
"Bass" "Treble" "Tuning" left to right . I think it should be "Bass" "Volume " "Band" " Tuning " left to right .Or something like that.
Also sticker did not stick or I did not do it right.So I glued it in a couple spots. I think if you get the correct labels it will be ok or better.
Sounds like you have a loose wire.Hopefully thats all it is and you will find it easily on the bench. Keep plugging !!!
Model 41-280 "slide Rule" dial - by bill T - 11-07-2005, 07:50 AM
[No subject] - by Bill Hutchinson - 11-07-2005, 11:31 AM
[No subject] - by bill T - 11-08-2005, 07:50 AM
[No subject] - by bill T - 11-19-2005, 11:43 AM
[No subject] - by Bill Hutchinson - 11-19-2005, 05:35 PM
[No subject] - by bill T - 11-22-2005, 02:52 PM
[No subject] - by Bill Hutchinson - 11-22-2005, 07:58 PM
[No subject] - by bill T - 11-23-2005, 01:07 AM
[No subject] - by Bill Hutchinson - 12-01-2005, 02:50 PM
[No subject] - by bill T - 12-03-2005, 08:01 AM
[No subject] - by Bill Hutchinson - 01-04-2006, 05:52 PM
Philco 91 Tuning Condenser
There are currently 9750 online users. [Complete List]
» 1 Member(s) | 9749 Guest(s)
