Scott 800B: The tuner
Not the tuning, just the operation of the bandswitch (preset) buttons.
Scott 800B: The tuner - by BrendaAnnD - 11-11-2013, 08:58 AM
RE: Scott 800B: The tuner - by morzh - 11-11-2013, 11:57 AM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-11-2013, 03:37 PM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-11-2013, 09:56 PM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-11-2013, 10:39 PM
RE: Scott 800B: The tuner - by Arran - 11-12-2013, 01:03 AM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-12-2013, 01:43 PM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-14-2013, 06:04 AM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-14-2013, 01:13 PM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-15-2013, 10:43 AM
RE: Scott 800B: The tuner - by Chuck Schwark - 11-15-2013, 10:54 AM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-15-2013, 01:30 PM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-15-2013, 08:43 PM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-15-2013, 09:23 PM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-17-2013, 12:55 AM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-17-2013, 01:15 AM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-17-2013, 01:46 AM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-17-2013, 10:34 PM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-17-2013, 11:35 PM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-18-2013, 12:02 AM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-18-2013, 12:10 AM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-18-2013, 07:00 PM
