Philco 16B Restoration
I found a suitable Hex tool to adjust the IF's and other trimmers and proceeded to do a full alignment as per the service sheets. All I can say is that the settings were way off.. The radio now booms in loud and clear with only a short aerial of a few feet. The shadow meter also worked better after the full alignment. Another project completed and satisfied owner.
Philco 16B Restoration - by prado.au - 11-01-2013, 06:14 PM
RE: Philco 16B Restoration - by Arran - 11-01-2013, 10:17 PM
RE: Philco 16B Restoration - by prado.au - 11-05-2013, 03:30 AM
RE: Philco 16B Restoration - by prado.au - 11-05-2013, 03:51 AM
RE: Philco 16B Restoration - by prado.au - 11-17-2013, 05:11 PM
There are currently 9687 online users. [Complete List]
» 1 Member(s) | 9686 Guest(s)
