38-7 audio "buzz"
Did you change the .015 caps in the bakelite as well? I just dealt with the same issue on a model 60 I'm working on. Changed the cap where the power cord connects and the buzz went away. I don't claim to know what I'm doing, but that worked for me in that situation.
38-7 audio "buzz" - by TonyJSenior - 04-21-2008, 03:44 PM
[No subject] - by justlrnin - 04-21-2008, 05:38 PM
[No subject] - by TonyJSenior - 04-21-2008, 06:40 PM
[No subject] - by Chuck Schwark - 04-21-2008, 09:27 PM
[No subject] - by Texasrocker - 04-21-2008, 11:06 PM
[No subject] - by Chuck Schwark - 04-21-2008, 11:10 PM
[No subject] - by TonyJSenior - 04-21-2008, 11:21 PM
[No subject] - by Chuck Schwark - 04-21-2008, 11:28 PM
[No subject] - by Texasrocker - 04-21-2008, 11:32 PM
[No subject] - by gary rabbitt - 04-26-2008, 10:24 PM
[No subject] - by exray - 04-27-2008, 01:14 AM
Philco 91 Tuning Condenser
There are currently 10063 online users. [Complete List]
» 1 Member(s) | 10062 Guest(s)
