  • 1 Vote(s) - 5 Average
46-1201 model 128 restore and question
Sooooo, apparently i've made a faux pas. The last 3 tubes i mixed up. Sorry about that. The readings seem much better now. Here's the new readings.
46-1201 model 128 restore and question - by tig1 - 11-07-2013, 07:47 PM
RE: 46-1201 model 128 restore and question - by tig1 - 11-17-2013, 10:26 PM
