  • 1 Vote(s) - 5 Average
46-1201 model 128 restore and question
That's much better. Now it looks like resistor 27 is really the problem. You only have a half a volt on the plate pin 2 where there should be 55 V.
An open resistor 27 would be the cause since it should supply plate voltage to pin 2.
46-1201 model 128 restore and question - by tig1 - 11-07-2013, 07:47 PM
RE: 46-1201 model 128 restore and question - by Mondial - 11-17-2013, 10:47 PM
There are currently 9971 online users. [Complete List]
» 2 Member(s) | 9969 Guest(s)
