Philco 40-201 Speaker
One thing you may want to do is check the primary of your OT. It's common for them to go open. If it is OK then the closest thing you'll find will be a 3.2 ohms replacement. The original is 1.25 ohms.
Philco 40-201 Speaker - by Joeztech - 11-17-2013, 10:17 AM
RE: Philco 40-201 Speaker - by Radioroslyn - 11-18-2013, 09:06 AM
RE: Philco 40-201 Speaker - by Joeztech - 11-18-2013, 03:13 PM
RE: Philco 40-201 Speaker - by Joeztech - 11-18-2013, 06:18 PM
RE: Philco 40-201 Speaker - by BrendaAnnD - 11-18-2013, 08:11 PM
RE: Philco 40-201 Speaker - by Joeztech - 11-18-2013, 08:31 PM
RE: Philco 40-201 Speaker - by Joeztech - 11-19-2013, 06:49 PM
RE: Philco 40-201 Speaker - by Joeztech - 11-20-2013, 07:54 PM
RE: Philco 40-201 Speaker - by Ron Ramirez - 11-20-2013, 08:45 PM
RE: Philco 40-201 Speaker - by Joeztech - 11-20-2013, 08:52 PM
RE: Philco 40-201 Speaker - by Ron Ramirez - 11-20-2013, 09:04 PM
RE: Philco 40-201 Speaker - by Joeztech - 11-21-2013, 07:15 PM
RE: Philco 40-201 Speaker - by Joeztech - 11-21-2013, 07:54 PM
RE: Philco 40-201 Speaker - by Joeztech - 11-23-2013, 02:35 PM
RE: Philco 40-201 Speaker - by Ron Ramirez - 11-26-2013, 06:47 AM
RE: Philco 40-201 Speaker - by Joeztech - 11-26-2013, 07:52 AM
RE: Philco 40-201 Speaker - by Steve D - 11-26-2013, 09:12 AM
RE: Philco 40-201 Speaker - by Mondial - 11-26-2013, 06:49 PM
RE: Philco 40-201 Speaker - by Joeztech - 11-26-2013, 07:20 PM
RE: Philco 40-201 Speaker - by Mondial - 11-26-2013, 08:57 PM
RE: Philco 40-201 Speaker - by Joeztech - 11-26-2013, 09:01 PM
There are currently 10223 online users. [Complete List]
» 3 Member(s) | 10220 Guest(s)
