Model 620
Wow, What a web site. I've picked up a lot of info but now I have a Model 620 that is kicking my rear. A year ago I recapped the set and it was working fine. It was put away until I could get to the cabinet and now it has failed. No audio was being heard until I touched the grid of the IF tube. I suspected the IF coil but it has good continuity. All tube voltages appear good but if I touch the plate of the 6A7 Det/Osc with a meter probe the radio plays fine. I hope that all of the Philco knowledge out there can point me in the right direction. Thanks to this web site I was able to stop the squeal by rounding up four tube shields that the radio did not come with. Thanks in advance for the help that I know will come.
Dave D
Model 620 - by Dave D - 04-21-2008, 08:52 PM
[No subject] - by Terry Burns - 04-22-2008, 08:48 AM
[No subject] - by Dave D - 04-22-2008, 03:18 PM
[No subject] - by Terry Burns - 04-22-2008, 04:05 PM
Philco 91 Tuning Condenser
There are currently 4962 online users. [Complete List]
» 2 Member(s) | 4960 Guest(s)
