58th birthday present.
After looking over the chassis in more detail, and comparing it to the chassis layout diagrams, I found this to be a model 95 chassis, not the 76. All the better.
58th birthday present. - by Groundhog74 - 11-17-2013, 10:45 PM
RE: 58th birthday present. - by Arran - 11-18-2013, 01:47 AM
RE: 58th birthday present. - by TA Forbes - 11-18-2013, 03:15 AM
RE: 58th birthday present. - by PhilcoJohn - 11-18-2013, 09:47 AM
RE: 58th birthday present. - by Groundhog74 - 11-18-2013, 09:57 AM
RE: 58th birthday present. - by Gene Pederson - 11-18-2013, 05:54 PM
RE: 58th birthday present. - by GarySP - 11-18-2013, 07:19 PM
RE: 58th birthday present. - by Groundhog74 - 01-26-2014, 08:39 PM
RE: 58th birthday present. - by morzh - 01-26-2014, 09:22 PM
RE: 58th birthday present. - by PAradiogeek - 01-26-2014, 10:31 PM
There are currently 8758 online users. [Complete List]
» 3 Member(s) | 8755 Guest(s)
