Best Philco Day... two 16Bs!
I've been meaning to post a couple pictures for a while... I couldn't post them right when they were taken, because the shouldered 16B was a surprise for my friend LedHed.
Anyway, back in early April my better half and I drove down to Portland, OR to buy a couple radios. In a matter of an hour, we collected up TWO Philco 16Bs, the shouldered tombstone from a thrift store, and the peaked tombstone from a craigslist contact.
This picture shows the two radios in the back of my car, with the seller of the peaked tombstone, Joel, bravely saying goodbye to his baby. The peaked tombstone has an aftermarket BFO installed in it, with an extra 37 tube. Yes, this is the über-rare 12-tube 16B. Icon_wink
Rodney
Best Philco Day... two 16Bs! - by palegreenthumb - 11-19-2013, 02:52 AM
RE: Best Philco Day... two 16Bs! - by PhilcoJohn - 11-19-2013, 08:46 PM
RE: Best Philco Day... two 16Bs! - by Jayce - 11-19-2013, 09:25 PM
There are currently 9702 online users. [Complete List]
» 1 Member(s) | 9701 Guest(s)
