38-7 audio "buzz"
Your hand is touching the metal object and capacitively coupling house AC wiring fields (hum) into the circuit. It's called hand capacitance effect. Your body is essentially a big "capacitor." Same effect when you touch the grid cap on an audio tube to check if the audio section is alive. You hear the hum.
38-7 audio "buzz" - by TonyJSenior - 04-21-2008, 03:44 PM
[No subject] - by justlrnin - 04-21-2008, 05:38 PM
[No subject] - by TonyJSenior - 04-21-2008, 06:40 PM
[No subject] - by Chuck Schwark - 04-21-2008, 09:27 PM
[No subject] - by Texasrocker - 04-21-2008, 11:06 PM
[No subject] - by Chuck Schwark - 04-21-2008, 11:10 PM
[No subject] - by TonyJSenior - 04-21-2008, 11:21 PM
[No subject] - by Chuck Schwark - 04-21-2008, 11:28 PM
[No subject] - by Texasrocker - 04-21-2008, 11:32 PM
[No subject] - by gary rabbitt - 04-26-2008, 10:24 PM
[No subject] - by exray - 04-27-2008, 01:14 AM
Philco 91 Tuning Condenser
There are currently 10457 online users. [Complete List]
» 2 Member(s) | 10455 Guest(s)
