The second 800B tuner has arrived..
Do you have a link to those tone mods? I agree, there isn't much tone control, maybe +/- 3 dB or so, just judgeing by ear.
RE: The second 800B tuner has arrived.. - by BrendaAnnD - 11-19-2013, 07:15 PM
