Best Philco Day... two 16Bs!
Pale, Those Philco 16B's are great performers. I have the earlier 5 band peaked tombstone in my collection. Hope they work as good for you when finished.
Best Philco Day... two 16Bs! - by palegreenthumb - 11-19-2013, 02:52 AM
RE: Best Philco Day... two 16Bs! - by PhilcoJohn - 11-19-2013, 08:46 PM
RE: Best Philco Day... two 16Bs! - by Jayce - 11-19-2013, 09:25 PM
Philco 91 Tuning Condenser
There are currently 9750 online users. [Complete List]
» 1 Member(s) | 9749 Guest(s)
