Cleaning Up Chassis
If I have no rust I use Windex. Works just fine. Isopropyl alcohol also works fine.
if the dirt is stubborn and cannot be removed by either one I found out the Naval Jelly takes care of it and at the same time brightens the chassis. Just try not to let it get to the wiring.
Cleaning Up Chassis - by cwirth - 11-20-2013, 12:28 PM
RE: Cleaning Up Chassis - by klondike98 - 11-20-2013, 04:17 PM
RE: Cleaning Up Chassis - by morzh - 11-20-2013, 06:25 PM
RE: Cleaning Up Chassis - by jerryhawthorne - 11-21-2013, 05:18 PM
RE: Cleaning Up Chassis - by Bob Andersen - 11-21-2013, 05:35 PM
RE: Cleaning Up Chassis - by jerryhawthorne - 11-21-2013, 05:43 PM
RE: Cleaning Up Chassis - by klondike98 - 11-21-2013, 06:28 PM
RE: Cleaning Up Chassis - by Bob Andersen - 11-21-2013, 06:58 PM
RE: Cleaning Up Chassis - by tom.seeger - 11-21-2013, 11:40 PM
RE: Cleaning Up Chassis - by 37silverstreak - 11-23-2013, 12:40 PM
RE: Cleaning Up Chassis - by Joeztech - 11-23-2013, 03:00 PM
RE: Cleaning Up Chassis - by tig1 - 11-23-2013, 10:07 PM
There are currently 9778 online users. [Complete List]
» 3 Member(s) | 9775 Guest(s)
