Model 620
Hi Dave,
Great to hear you got it playing. I would really be interested to see the finished product. Icon_biggrin
Model 620 - by Dave D - 04-21-2008, 08:52 PM
[No subject] - by Terry Burns - 04-22-2008, 08:48 AM
[No subject] - by Dave D - 04-22-2008, 03:18 PM
[No subject] - by Terry Burns - 04-22-2008, 04:05 PM
Philco 91 Tuning Condenser
There are currently 10205 online users. [Complete List]
» 3 Member(s) | 10202 Guest(s)
