Cleaning Up Chassis
Here's my current arsenal for fighting rust. Take no prisoners Icon_e_smile
[Image: http://farm6.staticflickr.com/5536/10485...2f1e_c.jpg]
Seriously though - I recently tried Evapo-Rust for the first time and it's incredible stuff!
Acid free, non-toxic, doesn't harm other metals or plastics, and works great Icon_smile Similar to using Molasses, but a lot faster.
T-9 Boeshield is good follow up is you;d prefer to not paint. It's a thin solvent based wax you can spray or bush on the bare metal. Th solvent evaporates leaving a thin protective barrier.
Here's my current patient. It's tempting to chuck the whole chassis into Evapo-Rust, but I'm concerned about the tube sockets as mentioned above.
[Image: http://farm8.staticflickr.com/7370/10239...6860_b.jpg]
[Image: http://farm8.staticflickr.com/7429/10747...7087_c.jpg]
[Image: http://farm3.staticflickr.com/2810/10239...9f5a_c.jpg]
[Image: http://farm4.staticflickr.com/3807/10747...800b_c.jpg]
Icon_thumbup A little buffing will remove the discoloration.
[Image: http://farm4.staticflickr.com/3787/10767...107a_c.jpg]
Cleaning Up Chassis - by cwirth - 11-20-2013, 12:28 PM
RE: Cleaning Up Chassis - by klondike98 - 11-20-2013, 04:17 PM
RE: Cleaning Up Chassis - by morzh - 11-20-2013, 06:25 PM
RE: Cleaning Up Chassis - by jerryhawthorne - 11-21-2013, 05:18 PM
RE: Cleaning Up Chassis - by Bob Andersen - 11-21-2013, 05:35 PM
RE: Cleaning Up Chassis - by jerryhawthorne - 11-21-2013, 05:43 PM
RE: Cleaning Up Chassis - by klondike98 - 11-21-2013, 06:28 PM
RE: Cleaning Up Chassis - by Bob Andersen - 11-21-2013, 06:58 PM
RE: Cleaning Up Chassis - by tom.seeger - 11-21-2013, 11:40 PM
RE: Cleaning Up Chassis - by 37silverstreak - 11-23-2013, 12:40 PM
RE: Cleaning Up Chassis - by Joeztech - 11-23-2013, 03:00 PM
RE: Cleaning Up Chassis - by tig1 - 11-23-2013, 10:07 PM
There are currently 3957 online users. [Complete List]
» 1 Member(s) | 3956 Guest(s)
