Philco 1942 radio
I personally know John & Jean. They restore tube radios the correct way! They are GREAT people and they care about the way the radio is when completed. Very,Very happy with the radio I purchased from them!
Philco 1942 radio - by Shirley - 11-21-2013, 11:43 AM
RE: Philco 1942 radio - by jerryhawthorne - 11-21-2013, 06:13 PM
RE: Philco 1942 radio - by klondike98 - 11-21-2013, 07:00 PM
RE: Philco 1942 radio - by PhilcoJohn - 11-21-2013, 07:05 PM
RE: Philco 1942 radio - by Ron Ramirez - 11-21-2013, 09:45 PM
RE: Philco 1942 radio - by Arran - 11-21-2013, 10:38 PM
RE: Philco 1942 radio - by vinzer - 11-22-2013, 02:32 PM
There are currently 4288 online users. [Complete List]
» 3 Member(s) | 4285 Guest(s)
