My New Westinghouse
Thanks Brenda. One the one I had before, I could pick up SW but there is not much on several bands. What I do pick up usually is things I can't understand in another language. . But I like to make sure that the radio works as it should. There is one of the knobs on the side that rotates the antenna and that does make a difference. In total the radio has 7 knobs
My New Westinghouse - by Dan Walker - 11-21-2013, 11:12 AM
RE: My New Westinghouse - by Jayce - 11-21-2013, 12:40 PM
RE: My New Westinghouse - by BrendaAnnD - 11-21-2013, 03:27 PM
RE: My New Westinghouse - by jerryhawthorne - 11-21-2013, 03:40 PM
RE: My New Westinghouse - by PhilcoMike - 11-21-2013, 05:10 PM
RE: My New Westinghouse - by Dan Walker - 11-21-2013, 08:41 PM
RE: My New Westinghouse - by BrendaAnnD - 11-21-2013, 10:42 PM
RE: My New Westinghouse - by Dan Walker - 11-21-2013, 11:31 PM
RE: My New Westinghouse - by Jayce - 11-21-2013, 11:42 PM
RE: My New Westinghouse - by Dan Walker - 11-21-2013, 11:52 PM
RE: My New Westinghouse - by BrendaAnnD - 11-22-2013, 01:06 AM
RE: My New Westinghouse - by Joe Rossi - 11-22-2013, 11:45 AM
RE: My New Westinghouse - by Jayce - 11-22-2013, 03:15 PM
RE: My New Westinghouse - by BrendaAnnD - 11-22-2013, 03:58 PM
RE: My New Westinghouse - by PhilcoMike - 11-22-2013, 05:06 PM
RE: My New Westinghouse - by Paul Philco322 - 11-22-2013, 10:00 PM
RE: My New Westinghouse - by Arran - 11-23-2013, 01:04 AM
RE: My New Westinghouse - by TA Forbes - 11-23-2013, 11:52 AM
