  • 1 Vote(s) - 5 Average
Got bored today so took my 37-690 apart
Dr F. Was Igor there to help out, and when will the storm prevail?
Just kidding, but you are far braver than I. The coil: Doesn't look that nasty from the picture, someone may have rewound one and might chime in.
Got bored today so took my 37-690 apart - by Skip - 11-19-2013, 10:33 PM
RE: Got bored today so took my 37-690 apart - by codefox1 - 11-22-2013, 10:15 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 9152 online users. [Complete List]
» 3 Member(s) | 9149 Guest(s)
