16B works after 90% recap
The big brick cap can isn't all that hard to redo, I take it off the chassis, drill out the two rivets and then put it on a scrap pie pan and bake it in the oven at about 350 for about 45 mins but you could also do a heat gun and then get a long wood screw then take the bottom off and screw the wood screw in and get some gloves and pull the goo caps out. You could use electrolytics but I just use drops and put them in the cap can and then rivet the unit back together. I also usually paint it with "metallic paint" to get the original look back and then bolt it back and hook up the leads again.
16B works after 90% recap - by AI2V - 04-25-2008, 09:38 AM
[No subject] - by 49Stude63 - 04-25-2008, 10:01 AM
[No subject] - by Terry Burns - 04-25-2008, 10:36 AM
[No subject] - by Ron Ramirez - 04-25-2008, 06:21 PM
[No subject] - by 49Stude63 - 04-25-2008, 11:18 PM
[No subject] - by Ron Ramirez - 04-25-2008, 11:34 PM
VanDyke and big cap can - by AI2V - 04-26-2008, 10:13 AM
[No subject] - by 49Stude63 - 04-26-2008, 07:33 PM
[No subject] - by Texasrocker - 05-01-2008, 12:54 AM
[No subject] - by 49Stude63 - 05-01-2008, 08:55 AM
There are currently 7163 online users. [Complete List]
» 1 Member(s) | 7162 Guest(s)
