  • 1 Vote(s) - 5 Average
46-1201 model 128 restore and question
Yup, replaced #27 resistor and lots of volume! had to remove the cone to get all the grit and metal particles out of the center but sounds great now except for some buzzing and humming depending on the station tuned in. Could this just be an alignment issue? I still have some resistors i want to replace because they're over 10% off.
46-1201 model 128 restore and question - by tig1 - 11-07-2013, 07:47 PM
RE: 46-1201 model 128 restore and question - by tig1 - 11-23-2013, 09:59 PM
There are currently 8690 online users. [Complete List]
» 2 Member(s) | 8688 Guest(s)
