Philco 38-3XX tube - shielded???
I have a bit of a dilemma. The RF amp tube (a 6U7G) in my Philco 38-3XX console sits in a rather odd-looking socket base. THe socket itself is nothing out of the ordinary, but there is a piece riveted to the chassis that looks like a sort of short cylinder with two sides flattened out, and a hole in the top for the tube to go into. I presume that a shield is supposed to go over this cylinder, but it is the only thing of this type in the radio, and a standard round Philco tube shield is too big, and a Philco square shield is the wrong shape. Is a shield supposed to fit over this? It's at the lower left of the tuning condenser in this photo:
[Image: http://i294.photobucket.com/albums/mm100...744076.jpg]
If a shield IS supposed to fit over this, would someone PLEASE post a photo so I can send it to Mark Oppat at Old Radio Parts and get the RIGHT one? BOTH of us are getting a bit bewildered by this thing...
Philco 38-3XX tube - shielded??? - by Rich K. - 11-23-2013, 11:23 PM
RE: Philco 38-3XX tube - shielded??? - by Mondial - 11-24-2013, 12:24 AM
RE: Philco 38-3XX tube - shielded??? - by Rich K. - 11-24-2013, 09:26 AM
RE: Philco 38-3XX tube - shielded??? - by Rich K. - 12-01-2013, 05:17 PM
There are currently 10403 online users. [Complete List]
» 2 Member(s) | 10401 Guest(s)
