Is this a Philco 60 Chassis?
That's definitely a 60 chassis. Looks like it has been rebuilt a couple times under the chassis, so that might be causing confusion. I have a 60L just like yours in fact and it had to had a PM speaker adapted to it since the original had the cone torn out by someone's bratty kid years ago.
Is this a Philco 60 Chassis? - by RayDavis - 11-24-2013, 05:56 PM
RE: Is this a Philco 60 Chassis? - by Jayce - 11-24-2013, 06:04 PM
RE: Is this a Philco 60 Chassis? - by RayDavis - 11-24-2013, 06:13 PM
RE: Is this a Philco 60 Chassis? - by RayDavis - 11-24-2013, 07:56 PM
RE: Is this a Philco 60 Chassis? - by Phlogiston - 11-24-2013, 08:37 PM
RE: Is this a Philco 60 Chassis? - by TA Forbes - 11-25-2013, 01:38 AM
RE: Is this a Philco 60 Chassis? - by RayDavis - 11-25-2013, 11:45 AM
RE: Is this a Philco 60 Chassis? - by Jayce - 11-25-2013, 01:12 PM
RE: Is this a Philco 60 Chassis? - by Arran - 11-25-2013, 11:33 PM
RE: Is this a Philco 60 Chassis? - by RayDavis - 11-26-2013, 01:06 PM
RE: Is this a Philco 60 Chassis? - by Arran - 11-26-2013, 11:43 PM
RE: Is this a Philco 60 Chassis? - by TA Forbes - 11-27-2013, 11:18 PM
RE: Is this a Philco 60 Chassis? - by codefox1 - 11-28-2013, 09:38 PM
RE: Is this a Philco 60 Chassis? - by RayDavis - 11-29-2013, 12:25 PM
Philco 91 Tuning Condenser
