what kind of iron would be best 15w 20w 25w or more
I'm a big fan of the Weller SP40 pencil. 40 watts, nice 1/4" wide flat tip. If you're patient it will even do light chassis connections. They run about $16-18 these days.
For SS work I have the SP25 with the little 1/8" conical tip.
-Bill
[No subject] - by 49Stude63 - 04-24-2008, 08:30 PM
[No subject] - by Alan Douglas - 04-24-2008, 08:35 PM
[No subject] - by jerm - 04-25-2008, 08:58 AM
[No subject] - by 49Stude63 - 04-25-2008, 09:24 AM
[No subject] - by Ron Ramirez - 04-25-2008, 06:24 PM
[No subject] - by exray - 04-26-2008, 05:54 AM
[No subject] - by Texasrocker - 05-01-2008, 01:24 AM
Philco 91 Tuning Condenser
