Is this a Philco 60 Chassis?
The dial scale is a dead-give away.
It's a model 66, a MUCH better set in my opinion, as it has a wider shortwave band.
Not a tough set to wok on, sometimes the band switch freezes up.
Is this a Philco 60 Chassis? - by RayDavis - 11-24-2013, 05:56 PM
RE: Is this a Philco 60 Chassis? - by Jayce - 11-24-2013, 06:04 PM
RE: Is this a Philco 60 Chassis? - by RayDavis - 11-24-2013, 06:13 PM
RE: Is this a Philco 60 Chassis? - by RayDavis - 11-24-2013, 07:56 PM
RE: Is this a Philco 60 Chassis? - by Phlogiston - 11-24-2013, 08:37 PM
RE: Is this a Philco 60 Chassis? - by TA Forbes - 11-25-2013, 01:38 AM
RE: Is this a Philco 60 Chassis? - by RayDavis - 11-25-2013, 11:45 AM
RE: Is this a Philco 60 Chassis? - by Jayce - 11-25-2013, 01:12 PM
RE: Is this a Philco 60 Chassis? - by Arran - 11-25-2013, 11:33 PM
RE: Is this a Philco 60 Chassis? - by RayDavis - 11-26-2013, 01:06 PM
RE: Is this a Philco 60 Chassis? - by Arran - 11-26-2013, 11:43 PM
RE: Is this a Philco 60 Chassis? - by TA Forbes - 11-27-2013, 11:18 PM
RE: Is this a Philco 60 Chassis? - by codefox1 - 11-28-2013, 09:38 PM
RE: Is this a Philco 60 Chassis? - by RayDavis - 11-29-2013, 12:25 PM
Philco 91 Tuning Condenser
There are currently 9794 online users. [Complete List]
» 1 Member(s) | 9793 Guest(s)
