Flea Market Trio w/2 Philcos!
You will probably find that the Western Air Patrol set was made by Gilfillan, either Gilfillan or Packard Bell in the Los Angeles area.
Flea Market Trio w/2 Philcos! - by VntgRads - 11-24-2013, 04:29 PM
RE: Flea Market Trio w/2 Philcos! - by sam - 11-24-2013, 05:49 PM
RE: Flea Market Trio w/2 Philcos! - by VntgRads - 11-24-2013, 08:30 PM
RE: Flea Market Trio w/2 Philcos! - by TA Forbes - 11-25-2013, 01:40 AM
RE: Flea Market Trio w/2 Philcos! - by Arran - 11-25-2013, 02:02 AM
Philco 91 Tuning Condenser
There are currently 9329 online users. [Complete List]
» 2 Member(s) | 9327 Guest(s)
