Preparing 40-201 for painting chassis
Very well. Sounds like you will do just fine. I'd use a pipe cleaner and a little Deoxit on the tube sockets before you tape them up just for good measure. Also tape from inside any other various holes in chassis and redo any soldering to chassis if any before spraying.
Best!
RE: Preparing 40-201 for painting chassis - by codefox1 - 11-25-2013, 08:06 PM
