Preparing 40-201 for painting chassis
codefox1;
Yes, I have some Deoxit that I use for my stereo equipment maintenance. It is good to have around. Our cat likes to play with pipe cleaners, so we have a supply of those around.
There are some solder lugs on the top of the chassis that the grounding braid for the tuning capacitor solders to. I plan to cover those with tape before painting too so that soldering the capacitor back in place will not be a problem. Ditto for the ground lugs for the tuning control assembly.
Joe
RE: Preparing 40-201 for painting chassis - by Joeztech - 11-25-2013, 08:22 PM
