Is this a Philco 60 Chassis?
The model 66 is a year newer, it was the replacement for the 60 brought out in 1935. I have a 60L from 1933 but I think they carried that lowboy cabinet over into 1934 since the 1934 models have hex knobs and a Bakelite escutcheon. That cabinet was also used with the model 89 chassis and a few others, according to Ron's book and gallery. That cabinet may have been offered with a 66 chassis or it may be a Frankenradio, though a mild one since it's a bolt in.
I would use a filter choke rather then a Pi filter (resistor) either a traditional inductor or a solid state substitute. While you can get away with using a Pi filter in a five tube set a choke filters better with less voltage drop, it can always be bolted to the speaker basket along with the output transformer.
Is this a Philco 60 Chassis? - by RayDavis - 11-24-2013, 05:56 PM
RE: Is this a Philco 60 Chassis? - by Jayce - 11-24-2013, 06:04 PM
RE: Is this a Philco 60 Chassis? - by RayDavis - 11-24-2013, 06:13 PM
RE: Is this a Philco 60 Chassis? - by RayDavis - 11-24-2013, 07:56 PM
RE: Is this a Philco 60 Chassis? - by Phlogiston - 11-24-2013, 08:37 PM
RE: Is this a Philco 60 Chassis? - by TA Forbes - 11-25-2013, 01:38 AM
RE: Is this a Philco 60 Chassis? - by RayDavis - 11-25-2013, 11:45 AM
RE: Is this a Philco 60 Chassis? - by Jayce - 11-25-2013, 01:12 PM
RE: Is this a Philco 60 Chassis? - by Arran - 11-25-2013, 11:33 PM
RE: Is this a Philco 60 Chassis? - by RayDavis - 11-26-2013, 01:06 PM
RE: Is this a Philco 60 Chassis? - by Arran - 11-26-2013, 11:43 PM
RE: Is this a Philco 60 Chassis? - by TA Forbes - 11-27-2013, 11:18 PM
RE: Is this a Philco 60 Chassis? - by codefox1 - 11-28-2013, 09:38 PM
RE: Is this a Philco 60 Chassis? - by RayDavis - 11-29-2013, 12:25 PM
Philco 91 Tuning Condenser
