42-321 questions
Good morning, all
The pot was bad, so I bought a new one from AES. It has the round shaft as compared with the flat sided original shaft, but other than that, it will work just fine. I was thinking about using a dremel tool to grind a flat side on the new shaft. Has anyone done that? Or do I need to make the hole in the knob larger to receive the round shaft.
42-321 questions - by ke5yum - 11-14-2013, 09:20 AM
RE: 42-321 questions - by klondike98 - 11-14-2013, 08:18 PM
RE: 42-321 questions - by morzh - 11-15-2013, 12:00 AM
RE: 42-321 questions - by ke5yum - 11-19-2013, 09:20 AM
RE: 42-321 questions - by morzh - 11-19-2013, 02:39 PM
RE: 42-321 questions - by ke5yum - 11-20-2013, 08:56 AM
RE: 42-321 questions - by codefox1 - 11-20-2013, 04:35 PM
RE: 42-321 questions - by ke5yum - 11-26-2013, 08:51 AM
RE: 42-321 questions - by vinzer - 11-26-2013, 12:44 PM
RE: 42-321 questions - by ke5yum - 12-11-2013, 09:06 AM
RE: 42-321 questions - by klondike98 - 12-11-2013, 10:43 AM
RE: 42-321 questions - by ke5yum - 12-11-2013, 11:20 AM
There are currently 4990 online users. [Complete List]
» 1 Member(s) | 4989 Guest(s)
