Philco cathedrals- Where does the 19b fit in?
I have a line on an original model 19b cathedral that I think I can get for $100. I already have a 118b, a 60, 70, and a 90 cathedral, and Im trying to figure out how the 19B fits into the lineage. This style seems very different from the 70 and 90. Is it just in the styling of the cabinet or is there something more significant about it?
Philco cathedrals- Where does the 19b fit in? - by hunter2115 - 11-26-2013, 06:31 PM
There are currently 8851 online users. [Complete List]
» 1 Member(s) | 8850 Guest(s)
