Philco cathedrals- Where does the 19b fit in?
Pretty close.
M R Radios   C M Tubes
RE: Philco cathedrals- Where does the 19b fit in? - by Steve Davis - 11-26-2013, 10:42 PM
Philco 91 Tuning Condenser
