My totally revamped bucket list.
I would not mind one of the larger 1937-38 Philco consoles, but then again between the modular chassis and the coil problems they can be a dog so I am not going out of my way to acquire one.
My totally revamped bucket list. - by Jayce - 11-22-2013, 12:04 AM
RE: My totally revamped bucket list. - by Arran - 11-23-2013, 01:53 AM
RE: My totally revamped bucket list. - by Arran - 11-23-2013, 02:06 AM
RE: My totally revamped bucket list. - by Jayce - 11-23-2013, 09:00 PM
RE: My totally revamped bucket list. - by Arran - 11-24-2013, 12:43 AM
RE: My totally revamped bucket list. - by Jayce - 11-24-2013, 01:05 AM
RE: My totally revamped bucket list. - by Jayce - 11-25-2013, 02:03 AM
RE: My totally revamped bucket list. - by Arran - 11-26-2013, 11:52 PM
Philco 91 Tuning Condenser
There are currently 4678 online users. [Complete List]
» 2 Member(s) | 4676 Guest(s)
