Preparing 40-201 for painting chassis
Arran and Ron;
Thanks for this extra information. I spotted Krylon Brushed Nickel (did not look at the number on the back) at Ace Hardware, but did not think it was the right one. I found the Krylon Brilliant Silver no. 51511 at Walmart in my area. There is a Hobby Lobby in Denton, TX somewhat farther away. I have not opened the Krylon Brilliant Silver, so I could return it to Walmart for credit. Ron do you still have the can of Satin Nickel? If so take a look at the back side of the can for the number. That would nail it for sure. In the meantime, I will look on Krylon's website again and see if I can spot it.
Thanks in advance.
Joe
Thanks in advance.
RE: Preparing 40-201 for painting chassis - by Joeztech - 11-27-2013, 07:21 AM
