MORE Phonograph Woes
You would pretty much have to substitute it with a more modern cartridge, or rebuild the old one, unless it is one of those magnetic types. This is part of the hold up with my Bing Crosby, that and a wonky mercury switch.
MORE Phonograph Woes - by TA Forbes - 11-28-2013, 12:08 AM
RE: MORE Phonograph Woes - by Arran - 11-28-2013, 12:13 AM
RE: MORE Phonograph Woes - by TA Forbes - 11-28-2013, 12:34 AM
RE: MORE Phonograph Woes - by Arran - 11-28-2013, 12:54 AM
RE: MORE Phonograph Woes - by Warren - 11-28-2013, 02:31 AM
RE: MORE Phonograph Woes - by TA Forbes - 11-29-2013, 11:34 AM
RE: MORE Phonograph Woes - by Warren - 11-29-2013, 01:19 PM
RE: MORE Phonograph Woes - by TA Forbes - 12-04-2013, 09:18 PM
RE: MORE Phonograph Woes - by Warren - 12-05-2013, 12:42 AM
