Philco 42-380 alignment
I just noticed your dial is a little off kilter. Sure it's just cosmetic, but I had the same problem with my 42-380. Underneath the shelf where the chassis sits are four screws which hold it in place. Tightening or loosening these screws will compress or relax the rubber feet, one at each corner of the chassis. It's a simple way to level the dial with the escucheon.
Philco 42-380 alignment - by Ronin61 - 04-23-2013, 10:38 PM
RE: Philco 42-380 alignment - by Raleigh - 04-23-2013, 11:36 PM
RE: Philco 42-380 alignment - by PT57 - 11-28-2013, 02:42 AM
RE: Philco 42-380 alignment - by Ronin61 - 11-28-2013, 11:21 AM
