Philco 19 Restoration (from yet ANOTHER Newbie
VintageVolts Wrote:BTW, how do I remove the coil cans from the chassis?
You don't. They were spun on at the factory; any attempt to remove them will probably ruin them.
The coils are removable from underneath. Not the shields (cans), just the coils themselves.
RE: Philco 19 Restoration (from yet ANOTHER Newbie - by boxjoint - 09-26-2013, 02:58 AM
RE: Philco 19 Restoration (from yet ANOTHER Newbie - by Ron Ramirez - 11-29-2013, 05:22 PM
There are currently 11382 online users. [Complete List]
» 2 Member(s) | 11380 Guest(s)
