  • 1 Vote(s) - 5 Average
Zenith Stratosphere 1000Z Reproduction Cabinet
It is a beautiful work of art. I had the privilege of seeing it in person a few months ago. While not yet completely finished I was able to watch Kenny do some of the intricate inlay work. Kenny was able to source every exotic veneer used on the original cabinet.
RE: Zenith Stratosphere 1000Z Reproduction Cabinet - by Eliot Ness - 11-29-2013, 06:01 PM
