Cleaning Tuning Capacitor
morzh;
Yes I hate mice. They are nasty, filthy creatures that destroy everything around them. I found numerous spider webs and egg cases inside too. They all have to go!
Thanks for the information about the pink pearl eraser. There is another more modern type eraser that I often use which is an off-white almost gray color. It was originally created for artist work. One nice thing about this type is that it does not turn black when erasing pencil marks from paper. It is much more durable too and does not wear away as badly as a pink pearl eraser. I have never tried to use either type on switches since switch contacts are so delicate and extreme care needs to be used when cleaning them.
Now where did I misplace that screw!Icon_rolleyes
Joe
Cleaning Tuning Capacitor - by Joeztech - 11-24-2013, 11:35 AM
RE: Cleaning Tuning Capacitor - by codefox1 - 11-24-2013, 12:26 PM
RE: Cleaning Tuning Capacitor - by Phlogiston - 11-24-2013, 03:25 PM
RE: Cleaning Tuning Capacitor - by Joeztech - 11-24-2013, 03:36 PM
RE: Cleaning Tuning Capacitor - by morzh - 11-24-2013, 07:13 PM
RE: Cleaning Tuning Capacitor - by Joeztech - 11-24-2013, 07:57 PM
RE: Cleaning Tuning Capacitor - by ipwizard - 11-25-2013, 12:13 AM
RE: Cleaning Tuning Capacitor - by Joeztech - 11-25-2013, 07:24 AM
RE: Cleaning Tuning Capacitor - by Joeztech - 11-25-2013, 08:15 PM
RE: Cleaning Tuning Capacitor - by Joeztech - 11-28-2013, 05:53 PM
RE: Cleaning Tuning Capacitor - by morzh - 11-28-2013, 11:46 PM
RE: Cleaning Tuning Capacitor - by Joeztech - 11-29-2013, 07:30 AM
RE: Cleaning Tuning Capacitor - by morzh - 11-29-2013, 07:59 PM
RE: Cleaning Tuning Capacitor - by Joeztech - 11-30-2013, 08:04 AM
There are currently 10556 online users. [Complete List]
» 2 Member(s) | 10554 Guest(s)
