Found!--Zenith Model 7H820 Schematic
Eric,
I will PM you the schematic. It was too large to attach. Joe
Joe
RE: Found!--Zenith Model 7H820 Schematic - by Joe Rossi - 11-30-2013, 09:03 PM
