Philco 37-611 Restoration (Newbie Here)
So take your - lead from your meter and connect it to the off/on switch. set meter for DC volts. Measure the voltage on the pins of the 25A6 with the + lead . Report back.
There are currently 10378 online users. [Complete List]
» 1 Member(s) | 10377 Guest(s)
