Maggie CR-192 FM tuner
    Any Maggie lovers out there? I know they made top and bottom mount versions of the CR-192 tuners (A&B) but has anyone heard of a vertical mount CR-192? I bought one on ebay thinking I could put it in my Berkeley. It would fit but the faceplate would be upside down. Anyone have an extra faceplate?
Keith
Maggie CR-192 FM tuner - by keith49vj3 - 12-01-2013, 07:42 PM
RE: Maggie CR-192 FM tuner - by keith49vj3 - 12-03-2013, 01:37 PM
RE: Maggie CR-192 FM tuner - by codefox1 - 12-03-2013, 03:39 PM
RE: Maggie CR-192 FM tuner - by TA Forbes - 12-04-2013, 09:49 PM
RE: Maggie CR-192 FM tuner - by keith49vj3 - 12-05-2013, 07:13 AM
There are currently 5192 online users. [Complete List]
» 5 Member(s) | 5187 Guest(s)
AvatarAvatarAvatarAvatar
