38-62 Schematic
There doesn't seem to be a 38-62 on Nostalgia Air, but they do have a 37-62. From the descriptions in the photo gallery, it sounds as though the 37-62 might have carried over into 1938 as the 38-62 with little change. http://www.nostalgiaair.org/Resources/211/M0013211.htm
You can no doubt get a 38-62 Philco service package from Chuck Schwark. http://www.philcorepairbench.com/schematics.htm These packages are well worth it.
John Honeycutt
38-62 Schematic - by Bradley Rush - 12-02-2013, 08:52 AM
RE: 38-62 Schematic - by Raleigh - 12-02-2013, 02:14 PM
RE: 38-62 Schematic - by Ron Ramirez - 12-02-2013, 09:05 PM
There are currently 9738 online users. [Complete List]
» 1 Member(s) | 9737 Guest(s)
