A New Emerson Find
I recently picked up an Airline 62-361, and it has the same white/red "dial tape" indicator and 6 pushbuttons. I'm under the impression the Airline chassis was made by Wells Gardner. However I just checked Riders and it shows two complete schematics for the 62-361, with the main difference being that the 'B' schematic has all the (same) part numbers prefixed with BE. Did Belmont and WG make chassis for the same model radio? Did Emerson also put the same or very similar chassis in their radios? They look remarkably similar!
http://www.radiomuseum.org/r/montgomery_62_361.html. (Look at the last picture.)
A New Emerson Find - by Gene Pederson - 12-02-2013, 06:47 PM
RE: A New Emerson Find - by morzh - 12-02-2013, 10:38 PM
RE: A New Emerson Find - by palegreenthumb - 12-03-2013, 02:57 AM
RE: A New Emerson Find - by Gene Pederson - 12-04-2013, 06:20 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
