Hippo knobs
Didn't the ivory hippos have the reddish brown knobs?
Mike Koste
Gobs of Knobs
Zucksville, PA
Hippo knobs - by tab10672 - 11-28-2013, 09:10 PM
RE: Hippo knobs - by TA Forbes - 11-29-2013, 11:37 AM
RE: Hippo knobs - by Bob Andersen - 12-02-2013, 10:01 PM
RE: Hippo knobs - by ekimetsok - 12-03-2013, 10:37 AM
RE: Hippo knobs - by TA Forbes - 12-04-2013, 09:14 PM
RE: Hippo knobs - by Ron Ramirez - 12-04-2013, 09:24 PM
RE: Hippo knobs - by codefox1 - 12-08-2013, 04:10 PM
RE: Hippo knobs - by Jamie - 12-10-2013, 10:07 AM
Philco 91 Tuning Condenser
There are currently 7853 online users. [Complete List]
» 3 Member(s) | 7850 Guest(s)
