GE model G106 console.
Thanks!
I brought it up slowly on the bulbs this evening and was actually able to manually tune in WJER, though the sound is rather tinny right now and things obviously need gone through. Still, it is encouraging! Now... all that dried out rubber wire... Icon_eek
GE model G106 console. - by Jayce - 12-03-2013, 07:59 PM
RE: GE model G106 console. - by Radioroslyn - 12-03-2013, 08:51 PM
RE: GE model G106 console. - by Jayce - 12-03-2013, 10:31 PM
RE: GE model G106 console. - by palegreenthumb - 12-03-2013, 11:36 PM
RE: GE model G106 console. - by Jayce - 12-03-2013, 11:57 PM
RE: GE model G106 console. - by Arran - 12-04-2013, 01:50 AM
RE: GE model G106 console. - by Gene Pederson - 12-04-2013, 08:42 PM
RE: GE model G106 console. - by Jayce - 12-04-2013, 09:06 PM
RE: GE model G106 console. - by jontz - 12-05-2013, 08:12 AM
