Instant Philco Service "library"
Recently I came across Philco RMS Yearbooks, containing all of the schematics for Philco home and auto radios for the years 1939, 1940, 1941, and 1942. If that weren't enough, I then found the yearbook for the 1946-47 models, as well as a genuine Philco 3-ring binder containing the schematics for all of the 1948-49 models. I was one happy camper to obtain this useful service material!
Instant Philco Service "library" - by NostalgiaRadioTime - 12-04-2013, 12:17 AM
RE: Instant Philco Service "library" - by morzh - 12-04-2013, 10:49 AM
There are currently 10031 online users. [Complete List]
» 1 Member(s) | 10030 Guest(s)
