  • 1 Vote(s) - 4 Average
1938 Philco on "Lassie" TV show
COOL! That looks an awful lot like mine.....I'll bet it's EXACTLY the same one....I need to put it on the bay for sale.....$3500.00 sound like enough?
1938 Philco on "Lassie" TV show - by Ron Ramirez - 12-03-2013, 07:48 PM
RE: 1938 Philco on "Lassie" TV show - by shaler78 - 12-03-2013, 09:42 PM
RE: 1938 Philco on "Lassie" TV show - by Arran - 12-04-2013, 01:06 AM
RE: 1938 Philco on "Lassie" TV show - by Groundhog74 - 12-04-2013, 07:19 AM
RE: 1938 Philco on "Lassie" TV show - by Jamie - 12-04-2013, 11:21 AM
RE: 1938 Philco on "Lassie" TV show - by codefox1 - 12-04-2013, 11:37 AM
RE: 1938 Philco on "Lassie" TV show - by don'tdomelikethat - 12-04-2013, 11:52 AM
RE: 1938 Philco on "Lassie" TV show - by shaler78 - 12-04-2013, 08:36 PM
RE: 1938 Philco on "Lassie" TV show - by Arran - 12-06-2013, 03:50 AM
RE: 1938 Philco on "Lassie" TV show - by WyTex - 01-09-2014, 04:26 PM
Philco 91 Tuning Condenser
There are currently 8960 online users. [Complete List]
» 2 Member(s) | 8958 Guest(s)
