Instant Philco Service "library"
The RMS manuals are an outstanding resource for the respective model years. I also have the 39-42 manuals and have referred to them often!
RE: Instant Philco Service "library" - by morzh - 12-04-2013, 10:49 AM
RE: Instant Philco Service "library" - by TA Forbes - 12-04-2013, 09:20 PM
