  • 1 Vote(s) - 4 Average
1938 Philco on "Lassie" TV show
Darn... I should KNOW this, since I've watched that very episode at least 10 times (I have it on a DVD set I purchased some time ago with various episodes with both Tommy Rettig and Jon Provost, including the one where Jeff moves to Capitol City and leaves Lassie on the farm. Alas, the brain is a sieve anymore...
1938 Philco on "Lassie" TV show - by Ron Ramirez - 12-03-2013, 07:48 PM
RE: 1938 Philco on "Lassie" TV show - by shaler78 - 12-03-2013, 09:42 PM
RE: 1938 Philco on "Lassie" TV show - by Arran - 12-04-2013, 01:06 AM
RE: 1938 Philco on "Lassie" TV show - by Jamie - 12-04-2013, 11:21 AM
RE: 1938 Philco on "Lassie" TV show - by codefox1 - 12-04-2013, 11:37 AM
RE: 1938 Philco on "Lassie" TV show - by don'tdomelikethat - 12-04-2013, 11:52 AM
RE: 1938 Philco on "Lassie" TV show - by shaler78 - 12-04-2013, 08:36 PM
RE: 1938 Philco on "Lassie" TV show - by BrendaAnnD - 12-04-2013, 11:08 PM
RE: 1938 Philco on "Lassie" TV show - by Arran - 12-06-2013, 03:50 AM
RE: 1938 Philco on "Lassie" TV show - by WyTex - 01-09-2014, 04:26 PM
Philco 91 Tuning Condenser
There are currently 9012 online users. [Complete List]
» 1 Member(s) | 9011 Guest(s)
